It is currently Mon Aug 11, 2025 2:37 pm
PostPosted: Sat Nov 05, 2016 10:02 am
First name: Curtis
Last Name: Woodall
City: Houston
Zip/Postal Code: 77065
Hi,
Been around here for a long time sponging up information, first time poster. I've made two acoustic guitars, buying sides pre-bent (Martin 000-style) with relative success. Been building solid body electrics for years. Not a seller, just a guy that builds and finds a free home for instruments and tube amps (...and bamboo fly rods). Here is what I want to do. I am going to focus on Martin style (D28) dreadnoughts for the next few years, nothing else. I'd like to attempt to get good at one thing only for now. So, I want to build a side bending machine...for Martin-style dreds. I want to stay as close to pre-war spec as is reasonable....reasonable. I'm just wondering who, if anybody, has the best set of plans for a Martin-style dreadnought, since that is what the bender will be used for. I'm speaking of a "Fox type" using heating blanket, slats, etc. Also, is there any big advantage in using Baltic birch ply as opposed to box store birch plywood? I'm gentle on tools and not in a production environment, but I like quality/effectiveness as much as the next guy.
I guess an accurate guitar plan/drawing is really my main concern at this point. That will guide my thoughts and pre-build/tool-up efforts. I'm in no hurry and budget is secondary (but I like building my own tools/jigs).
Thanks for any thoughts or input.
curtis
"I need to hurry up, the years are going by far too fast"
PostPosted: Sat Nov 05, 2016 10:06 am
City: Tyler
There is no need to waste money on Baltic plywood for a bender. I've used birch lumber store plywood and mdf. If you go to Mike Doolins website you'll see his was made of particle board.
PostPosted: Sat Nov 05, 2016 11:25 am
A single purpose side bender heated with a blanket is a very simple device -- here's one used at the Whetstone School of Lutherie. Make sure to have a timer in the circuit!
http://acousticguitarconstructionforum. ... ?f=8&t=104
Ken Cierp
PostPosted: Sat Nov 05, 2016 11:47 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
What the others have said. Here's your plan, as good as they come.
http://www.stewmac.com/How-To/Blueprint ... _Plan.html
Ken
PostPosted: Sat Nov 05, 2016 12:06 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Check out John Hall at Bluescreek Guitars. He will have everything you will need to build the bender and I'm sure he can provide you with a period correct tracing of a pre-war D-28 guitar. Great to deal with and good prices.
Cal
These users thanked the author Cal Maier for the post: Dave Rickard (Sun Nov 06, 2016 8:31 am)
PostPosted: Sat Nov 05, 2016 2:33 pm
If you are using a silicone blanket, rather than light bulbs, you might as well go to a solid form rather than sides with bars between. Gives you better support.
Other than that , I use one like kenceirp shows with everything attached to the bending form rather than a separate frame.
PostPosted: Sat Nov 05, 2016 4:31 pm
State: Tennessee
cwood3 wrote:
Hi,
curtis
John Arnold has a very accurate tracing of his 1937 Herringbone D-28. John Halls 1937 template by Waldron Instruments is really close to the Arnold tracing and John Halls exterior molds fit the template perfectly. Good Luck
PostPosted: Sat Nov 05, 2016 8:42 pm
First name: Curtis
Last Name: Woodall
City: Houston
Thanks all, I shall heed the above
PostPosted: Sun Nov 06, 2016 8:32 am
City: Lawrence
Zip/Postal Code: 66047
Cal
^^^^^^^^^^^^ what he said^^^^^^^^^^^^^^^^^^
PostPosted: Sun Nov 06, 2016 8:35 am
City: Lawrence
I tried the bulbs and had problems then tried a blanket from John Hall and never looked back.
PostPosted: Sun Nov 06, 2016 11:41 am
All our production benders are heated internally with light bulbs -- the trick if you will, is to capture "all the heat", messing with and inside slat beside being a PIA is simply not effective. Our forms are lined with aluminum and permanently covered with aluminum. which is a quantum improvement.
Ken Cierp
PostPosted: Sun Nov 06, 2016 3:52 pm
I think so too.
Use 550 watts of bulbs until around 150, then the blanket goes on, with both on until about 220/250 depending, then cut the bulbs back to minimum on the rheostat.
Have to switch them off around 20 degrees before max. temp is reached though or it overshoots.
For better support underneath the side, I use 2 bottom slats, holding spring tension on the lowest one.
I find this seems to help with cuping, especially if I have some rift to flat sawn pieces and am using damp paper rather than spritzing the sides.
PostPosted: Sun Nov 06, 2016 7:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
+1 for John Hall. I used to love jig building, and I built a lot of them. John is a got resource for this stuff and much more.
PostPosted: Sun Nov 06, 2016 7:55 pm
First name: Curtis
Last Name: Woodall
City: Houston
OK, so I am getting the tracing from J. Hall.
Users browsing this forum: DennisK, pkdz, pullshocks and 14 guests
